Results 1 to 3 of 3
Thread: Rns510 - r36
    Nov 2009
    Rns510 - r36
    I have retro fitted a RNS510 to my R36 and the audio menu is no longer visable and the track/station can no longer be controlled by the steering wheel controls. The controls still work for other functionality.
    Can anyone with a passat with RNS confirm that the audio menu and track selection should still work?
    If so does anyone have ideas how I can make them work? The dealer wasnt any help.
    Thanks
    Adelaide hills, SA
    You most likely need someone with the VCDS cable to change the coding. Look in here who is close to you and try to get in touch. http://www.vwwatercooled.org.au/foru...elp-27504.html
    Sep 2011
    Exact same issue on another forum:
    Passat R36 Forum - R36Owners.NET - Passat R36, 3.6 V6 DSG • View topic - RNS 510
    Coding is almost definitely the problem. I saw exactly the same thing when I did the install in my GTI, it's a very simple fix once you find someone that can do the coding. I'm also in Melbourne, PM me and let me know where you're located, perhaps I can help.
