Results 1 to 8 of 8
Thread: RNS510 Music Streaming
    Apr 2015
    Deception Bay
    Need help please, I installed a RNS510 into my 2010 MkV 125kw 2.0 TDI Jetta yesterday, Head unit Part no: 1T0035680D, HW Version: H70, SW Version: 4120, Map Version: HDD 7492 and had a exsiting Bluetooth Module Part no: 7P6035730B SW: 0440 HW: H05
    First issue: My music plays through the bluetooth from my Iphone 6, but I can't see any track names on the Head unit or the MFD and can't select or skip tracks via the Head unit or Steering wheel buttons, only via the phone.
    Second issue: When the coding was done I had the compass and heading for Satnav on my MFD but lost my Climatronic And OPS sensor displays on the head unit, we changed the coding so I have Climatronic and OPS displayed on the head unit but now lost the compass and heading display on MFD.
    Any ideas what might be causing this?
    Thanks
    Jacques
    2010 VW Jetta MKV 125kw TDI RNS-510 GTI MFSW with Paddles
    Aug 2013
    Quote Originally Posted by Jacques View Post
    Thanks
    Jacques
    I believe the 7P6035730B is the early version of 9w7 Bluetooth module that lacks some features like track information, selecting or skipping tracks, and voice activation...
    I'm not 100% sure about that though.
    That's a 9ZB unit.
    Whilst it supports A2DP (streaming music profile) it does not support AVHCP v1.3 which is required to allow track information to be displayed on the head unit and MFD. AVHCP v1 allows the steering wheel controls to skip tracks etc. This is also only supported with the newer 9w7 modules.
    Apr 2015
    Deception Bay
    Thanks for youre reply's VEXED and KAMOLD, will look into getting a newer version bluetooth module, now to figure out the second issue why my MFD and Head Unit display aren't speaking to each other🤔
    Those two features are not mutually exclusive.
    Are you able to post a full autoscan of your car?
    Apr 2015
    Deception Bay
    Hi Kamold
    No I haven't got access to a vcds to upload a autoscan.
    Apr 2015
    Deception Bay
    Okay I installed a 7P6035730J module this morning, bluetooth music streaming issue sorted can see track info and skip via steering wheel controls.
    Now to short out my MFD display issue, could a it be BAP related issue where my climatronic unit not is speaking to the head unit and MFD
    Thanks for all the help so far😃
    Jacques
    Yes it sounds like a coding issue, but in order to debug it you'll need to find out what your current coding is.
