The Lithuanian seller sent me the replacement screen for the unit so must say I am pleased with the outcome !
If the problem is firmware related which it sounds as though it might be then it must be compatible with earlier firmware versions. If you can find out what version the current bluetooth module you have will work with then you could still sell the old bluetooth module to someone with an earlier model RNS / MFD and recoup a couple of $'s towards the new kit. Just a thought anyway![]()
Russ
2005 Subaru Outback 3.0 R Premium
I haven't fitted the replacement screen yet but I went for a drive out to Wisemans Ferry yesterday and the unit had trouble recognising our location on the map and turned itself off about 8 times. I reset it twice but it kept occuring. A little worried to say the least !!
