Hi,
I would advise you give a few more details about your car especially the year model .... Does it have the full sized MFD or only half size ? If it only has the half sized MFD then you could have a few issues, not only with trying to get the song titles etc... to show but chances are if it is only a half sized display then you could also find that you will have the battery drain issue and will either need to change the head unit or change the CANBUS. Not trying to cause you any undue worries but without knowing a few more details about the car it's pretty much impossible to know exactly what's happening. If you do have the later CANBUS and the full sized MFD then the chances are you will need someone with VAGCOM to make suitable adjustments to enable the functions, failing this you'll have to take it to a VW dealer and get them to look at it for you.
Russ
2005 Subaru Outback 3.0 R Premium
