Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: RNS510 help!
    Jun 2023
    Novi Sad
    You need to burn discs really slowly and use good quality ones Not Princo crap or stuff like that , And not rewriteables
    i burn them at 1x with imgburn, and i use verbatim cd-r discs, the map update as well swl_fix work perfectly fine but the other fw updates(except fw5238 by josi) do not even start
    2.0TDI 172bhp DSG '08 Touran Highline; 18'' AMG alloys; RNS510; Xenon headlights...
    Mornington Peninsula, VIC
    Can you give us a bit more background on the unit? Did you buy it second-hand from a wrecker, or was it a known good unit?
    Here is the link to the teardown and SSD update that johnc made RNS-510 HDD replacement/SSD swap DIY ; if the HDD has died, I would recommend going to an SSD or CF card with an adaptor like in that guide.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Jun 2023
    Novi Sad
    Quote Originally Posted by MIG View Post
    i got it as a gift from a friend because the touch stopped working.. i used the old erasing rubber trick on all connection cables and the touch works perfectly.. i wanted to update fw because of v17 east europe maps and it failed on hdd part of update..now with swl_fix the touch is working and unit only takes fw5238 update and still fails on hdd part :/
    Pacific Paradise QLD
    Will 5238 actually work with Euro maps Isnt the map capacity too small for them
    Jun 2023
    Novi Sad
    well it did work when it was installed but the unit does not register touch on radio code screen
    Mindarie, Perth (WA)
    There are mutltiple variations of 5238 (EURO/NAR/AusNZ).
    Kamold (I believe) set up the AusNZ version which partitioned the HDD into 90/5/5% partitions.
