Upgrade to SW 5238 from here
Firmware updates for RNS510 units in Australia/NZ
From an earlier post from Kamold " I've just updated the original post. Bottom line is 5238 is suitable for all units"
Hey guys I just bought a mk5 golf gt sport that has a rns510. It all works fine but I can not search street names when I won't to navigate somewhere.
It has the latest maps and j have the original v8 disk.
This is what the software info says
Delivery part number 3c0035684e
Hw version h03
Sw version 2604
Maps Australia nz and the latest v8
Any help or tips would be great???
Thanks
Define "it all works fine"... Are you talking about everything else other than the navigation or what?
Do you see anything on the map screen? streets and such?
also... have you tried turning it off and on again?
Try goes from 3D to 2D it only shows the street names while the map is in 2D
Sounds about right does that since V5 and is still the same Depends on the amount of zoom you have Have checked on each version and it does it in all of them I use 3D most of the time
Everything on the unit works except when I search for a place to navigate to. I see a map and streets. When I search the postcode works. Type any Main Street and it will not be there
So you reckon this will fix the problem of not being able to search for street names?
I see them but it will not show up when I'm searching for address
Firstly make sure you have the correct postcode for the strret you want. Some that you think my be in say 9999 may actually be in 9998.
Been caught like that a few times with ones right on the extremities
Or thinking it is in City named Smith when its actually in City named Jones
Had that with a road in the country and ended up not finding the correct road which was only a kilometer from the one it found with a similar name. Because it was in a different named locality.
The joys of owning a crap VW navigator
No matter the street I get nothing show up when I search. It's just blank when I put any street in
