Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 55
Thread: Rns510 help!?
  1. #41
    May 2016
    Port Macquarie
    That sucks, how much do I sell it for? Ideally I would like not to spend any or much money at all
  2. #42
    Just check on eBay what they are going for. You won't be able to get a straight swap as far as price is concerned unfortunately
    Sent from my HTC One_M8 using Tapatalk
  3. #43
    http://www.vwwatercooled.com.au/foru...d.php?t=113301
  4. #44
    May 2016
    Port Macquarie
    Shouldn't bother trying to update software to the latest for my unit?
    I can't find any others the same as mine to see how much I can sell it for.
  5. #45
    Pacific Paradise QLD
    Sell it as it is cos the software on here is NOT SUITABLE for North American units.
  6. #46
    May 2016
    Port Macquarie
    The only thing that doesn't work is I can't navigate to anywhere, other than that everything else works.
    Need to find out how much it's worth on eBay
  7. #47
    VW RNS 510 with Code Navigation Radio CD DVD MP3 Map GPS SD Card V34 020 | eBay
    This is the same hardware as yours, just has had software updated on it.
  8. #48
    Jan 2016
    Bankstown, NSW
    RNS510 Help!?
    Hello RNS Gurus,
    I too need help with my RNS510 unit.
    Since buying the R36 second hand last year the RNS has not worked properly.
    No OPS
    No media capability, with not read SD card, hangs on media start up.
    Bluetooth will not pair with iPhone
    Radio and Navigation work fine.
    The marking on the case of the unit is as follows;
    1T0 035 680 B
    HW: H11
    SW: 1200
    000532850
    Continental
    A2C53388884 VD1
    I am not able to bring up the Version Info screen when pressing and holding the Setup button.
    Have performed a reset to factory defaults, with no change to it's operability.
    Any suggestions on getting this unit to normal working condition?
    I would like in future, to upgrade to RVC.
    Thanks.
  9. #49
    Try and install 5238 firmware on it.
    You are likely running the original software.
    Then test the unit.
  10. #50
    Jan 2016
    Bankstown, NSW
    Thanks Kamold,
    I do not have the original VW map DVD, will this be a problem?
    If I need to relaod map data, can I source it from anywhere else?
    2009 Jetta 125 TDI Highline
    2018 Amarok V6 Sportline
    SOLD: 2010 R36 Wagon| Icelandic Grey| Tailgate| RNS| Sunroof|
