Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
Thread: Rns510 help!?
  1. #21
    It is highly unlikely that you have a US version, although not impossible. Why do you suspect this?
    Pull the unit out from the dash enough to take a look (and photo) of the sticker on the top. This has the information you need about part number, firmware version etc.
  2. #22
    Pacific Paradise QLD
    Well it always helps to know all the info at the start or you could brick the unit by not telling us and we inadvertantly give you wrong advice.
    SO DONT load what we have told you as you will see that the firmware is NOT SUITABLE for USA versions.
    As in the OP of the other thread "Also this is definately NOT suitable for North America units."
    You will have to go to one of the othere VW sites and look for suitable firmware.
    Kamold beat me to it so do what he said.
  3. #23
    May 2016
    Port Macquarie
    So the part number I see on the screen isn't enough and I should take the unit out and look at the sticker? What's the easiest way to get pic of sticker with out taking it fully out?
  4. #24
    The firmware version you have suggests its an EU unit. In which case load 5238.
    You'll have to explain why you think otherwise.
  5. #25
    May 2016
    Port Macquarie
    My Delivery part number 3c0035684e??? Or does that mean nothing?
  6. #26
    The reported part number from the screen can be modified with software.
    The sticker on top cannot.
    The delivery part number you have suggests a North America unit, the firmware version suggests EU...
  7. #27
    Looking around it seems the part number equates to a USA vers
    US Spec RNS 510 VW NavegaciĆ³n RNS510 MFD3 3C0035684E HD SW 4366 2015 Mapas Vim | eBay
    Others with same Pn number are advertised as or in the USA
  8. #28
    May 2016
    Port Macquarie
    Ok so easiest way to get to the sticker?
  9. #29
    Pop the surround off carefully, undo the 4 screws, pull unit forward, read and photograph the sticker. Post here. Only way to do it
  10. #30
    May 2016
    Port Macquarie
    How do I put a pic up?
