Results 1 to 10 of 13
Thread: RNS510 GPS InAccuracy
    Jul 2009
    Singapoe, Singapore
    Hi,
    I've got an RNS510 fitted to replace the original RCD310.
    What we've noticed is even with about 7 satellites locked on with a 3D fix, we are usually more than 100 meters away from known GPS co-ordinates.
    We used Holux, Garmin and other devices.. which had very similar GPS co-rodinates read out in a specific location.. but the RNS510 gave a very different reading.. > 100 meters away.
    Did anyone experience a similar issue? (about 2 seconds North, and 5 seconds East out-of-position).
    Thanks all in advance for any feedback/suggestions
    Jan 2009
    brisneyland
    Quote Originally Posted by hannson View Post
    Hi,
    It could be your GPS datum... might be worth looking through the settings for this.
    "One art please!" --->http://benno.redbubble.com
    Jul 2009
    Singapoe, Singapore
    Quote Originally Posted by benno View Post
    thanks benno!!
    That's what I thought too.. but I've not idea what settings to check with regard to this..
    Cheers!
    Jan 2008
    Check in the setup screen (the one on startup).
    Check the GPS antenna location.
    Check the version of firmware (see in the startup setup).
    Jul 2009
    Singapoe, Singapore
    Quote Originally Posted by Maverick View Post
    hi.. er..
    i can get into the setup screen.. as well as the secret setup screen (vagcom adaption channel 50 set to 1)..but there is no "Datum" setting.
    If you are referring to Almanac.. the status has been VALID, even with the GPS antenna disconnected for more than 7 days.
    1. GPS antenna (when connected) is at dash and can connect to about 7 satellites of 11, with a 3D fix
    2. firmware 1100
    hannson,
    This is a known issue with the Singaporean maps on the RNS510 - when I was recently there, I experienced it in 2 new VW's fitted with the RNS.
    I don't know why they can not sort it out.... But the cars we were in had a Tom Tom stuck to the windscreen for directions as well..
    P.S. - depending on your version of RNS (Part number) VW have now locked you out of the "startup - setup screen"
    Feb 2009
    Guy - am I right in saying that with the latest ones you need VAGCOM to do RNS510 setup?
    No, even by changing the adaptation setting's it just won't allow you in.
    We are yet to find out if there is any access at all.
    We now have the latest ones here "C" versions & they are locked out as well. Only the "no prefix" & "A" would let us in there (up to a certain firmware level)
    Feb 2009
    How bizarre...
