Hi,
I've got an RNS510 fitted to replace the original RCD310.
What we've noticed is even with about 7 satellites locked on with a 3D fix, we are usually more than 100 meters away from known GPS co-ordinates.
We used Holux, Garmin and other devices.. which had very similar GPS co-rodinates read out in a specific location.. but the RNS510 gave a very different reading.. > 100 meters away.
Did anyone experience a similar issue? (about 2 seconds North, and 5 seconds East out-of-position).
Thanks all in advance for any feedback/suggestions
"One art please!" --->http://benno.redbubble.com
Check in the setup screen (the one on startup).
Check the GPS antenna location.
Check the version of firmware (see in the startup setup).
hi.. er..
i can get into the setup screen.. as well as the secret setup screen (vagcom adaption channel 50 set to 1)..but there is no "Datum" setting.
If you are referring to Almanac.. the status has been VALID, even with the GPS antenna disconnected for more than 7 days.
1. GPS antenna (when connected) is at dash and can connect to about 7 satellites of 11, with a 3D fix
2. firmware 1100
How bizarre...
