Originally Posted by
NinetySix
Considering what you have now is widely regarded as having quite good sound, I'd be very cautious about taking any backwards steps.
I'm not aware of anything built into any kind of aftermarket head unit that would come close to the likes of a standalone DSP such as a minidsp, helix, mosconi etc etc.
It's getting harder and harder to beat the sound quality of an OEM head unit with something aftermarket, even from traditional brands once known for good car audio gear. Not saying it can't be done, and I can't comment on modernising the rns510 experience, but you should probably wash your mouth out for mentioning AliExpress in the same post as Dynaudio
Haha yeah, absolutely - AliExpress = "cheap Chinese garbage" (typically)
AFAIK - most of the Dynaudio magic happens in the amp. It has it's own DSP that is 'hard-coded' to the passat cabin and has built-in sound correction etc to help cleanup the RNS-510 signal.
An RCD 330+ would be a good option, but still a small 6.5" @ 800x480 screen - same as the existing RNS-510. There are a couple of Alpine and Pioneer units that look interesting in the 9" screen size range. Some have separate sub output and control over timings and frequency filters etc. The high-end Alpine options are comparable in price to a Helix DSP - not as good from a DSP perspective, but dunno if I actually need all of that with the current amp already tuned to my car.
I guess I was hoping for some definitive brand or model that was considered good quality - I'm seeing a bunch of new brand names pop up in this category that I have no idea about.. eg. Joying, Eonon etc - and you can't trust the online review sites ¯\_(ツ)_/¯
