Results 1 to 10 of 12
Thread: RNS510 - Do i need a CANBUS upgrade for the MY07 MKV 2.0TDI??
    NSW, Sydney
    Hi All, i have done a search on this forum and cant get a Professional answer on this.
    Do i need to Upgrade anything before i attempt to install a Version C L.E.D RNS510 (With latest firmware)
    as i have purchased one off eBay for around the $1000.00 mark landed which i think was brilliant value, however i hear if i need to upgrade my CANBUS (to avoid the dreaded battery drain) then it will cost a few hundred dollars and which canbus to buy and where from.
    Can anyone give me some correct advice??
    Cheers,
    robbie
    Jul 2010
    Robina Gold Coast
    Quote Originally Posted by robbie View Post
    Cheers,
    robbie
    I think the Mark V are ok the earlier models had a problem with battery drain , mines a Golf V 2008 and i have no issues.
    Jul 2005
    Newcastle, NSW
    You need to be careful as cars that were MY07 had different CANBUS over the build year - you need to check your controller part number ideally to be sure and follow the instructions here.
    Upgrading 2nd generation radios (RCD 300, RCD 500) to 3rd generation (RCD 210, RCD 310, RNS 310, RCD 510) power drain issue | my-gti.com
    FWIW - I had an MY07 built 11/06 and it had the drain issues.
    NSW, Sydney
    what about a friend of mine who has a 06 build date and compliance of 1/07
    Jul 2005
    Newcastle, NSW
    Need to replace it for sure. Did you read the info in the link it is pretty clear.
    NSW, Sydney
    cheers mik
    NSW, Sydney
    how much is this going to set me back and where should i buy it from and how much should i roughly spend on one and what part numbers for the later canbus i need
    NSW, Sydney
    need this question answered
    Mar 2009
    UMG Brisbane
    Patience Robbie. No need to double post, people will help, unless you keep doing things like that, in which case you'll get a reputation as a pest.
    Back on topic, the cheapest place to buy them is either the Skoda parts link in the My-GTi link, or off Fleabay. All the part numbers are in that link too for you to go searching. I'd also strongly suggest against creating a "is this a good one to buy" thread too.
    Al..
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    NSW, Sydney
    al the skoda parts link hasn't got any on their website and where on ebay can i find one that is suitable looked everywhere
