Rns510 will drop straight in and as the newer jetta no worries about canbus issues. You will need a gps antenna that you can located behind the dash. Then code the RNS to the dash so you get directions etc on the cluster. Will work with factory BT fine and display calls and phone book etc. If you install a reverse camera then you will need to wire all through the car and then code head unit for camera so it displays your picture. Basically the higher the last letter of the part number the newer the unit is...
