Post some pics of the version and HDD info screens from test menu, see if there are any clues there...
seems to have worked after I came back to the car tonight. once again I have another problem though. my Bluetooth audio streaming is no longer working. it allows me to press play and pause. and it works on my iPhone. but there is no soundthe mdi and radio work. but bt streaming is not. any ideas?
The Bluetooth volume by default is set very low from memory. Try going into setup->media and set bluetooth volume to medium or high (I think you have to already have the phone paired and Bluetooth streaming playing)
Firstly, I assume the iphone is paired with the RNS-510?
Here is a demo of the steps..
Volkswagen RDC-510: Bluetooth Audio Streaming - YouTube
When the phone is paired and you start up ipod, there is like an arrow sort of icon down the bottom (don't have a bluetooth device with me so can't pair my phone to look at it and describe it better). You click on this and it allows you to select where you want to route the audio...
Yep it's fully paired, phonebook and calls all works fine.
And yep i knew this because it worked on the other firmware hahaha.
it comes up with the option to play, pause, skip under media.
pressing play does make the song play on the phone and pause likewise.
The audio routing is set to the rns and not iphone, but there is no sound.
Ok then not sure what the problem is sorry...strange.
Plug it in via MDI? At least then the phone will charge![]()
