Page 18 of 21 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 204
Thread: RNS510 Australia V4 maps out ?
  1. #171
    Apr 2010
    Are you able to take a photo of said nicer icons/displays for us?
    Thanks
  2. #172
    Aug 2011
    vic
    Thanks
    Going to do the downgrade today, my unit is version D, and hw50, is that still okay :S
  3. #173
    Yep you can go ahead with the downgrade. All supported.
  4. #174
    Aug 2011
    vic
    Used the recovery cd, turned on downgrade, then used the 2760_all image first bar got to 100%, then AAPL got to 10% and i got error" 010302".
    Not sure what to do now
  5. #175
    Most likely can't read the cd.
    Try another disk (or even a DVD) and make sure you burn at slowest speed possible.
  6. #176
    Aug 2011
    vic
    Tried again with another DVD, and redownloaded firmware from mygti, same error, this time at 5% AAPL update
  7. #177
    They can be a bit temperamental with some brands of media however I have not had any problems with mine even with really crap cdrs.
    Try a different brand cdr or use another drive to burn the cd image. If it still fails try posting on vwnavi forums as those guys are the gurus.
  8. #178
    Aug 2011
    vic
    Hmm okay this is a bummer
    Seems to work after using the SWL recovery thing.
    edit: i mean, its functional, but its not updated duh.
  9. #179
    Aug 2011
    vic
    Quote Originally Posted by vraptor View Post
    Yay, used a different burner and it worked, only thing is it asked for maps cd, inserted the dvd i made from the maps iso, and then it said sucess, pressed eject but when i press maps its just blank :S
  10. #180
    you have to leave the map dvd in for like half an hour or so. Takes a while to copy. Select nav, then when you press eject it should prompt you that its not loaded yet...
