Are you able to take a photo of said nicer icons/displays for us?
Thanks
Yep you can go ahead with the downgrade. All supported.
Used the recovery cd, turned on downgrade, then used the 2760_all image first bar got to 100%, then AAPL got to 10% and i got error" 010302".
Not sure what to do now
Most likely can't read the cd.
Try another disk (or even a DVD) and make sure you burn at slowest speed possible.
They can be a bit temperamental with some brands of media however I have not had any problems with mine even with really crap cdrs.
Try a different brand cdr or use another drive to burn the cd image. If it still fails try posting on vwnavi forums as those guys are the gurus.
you have to leave the map dvd in for like half an hour or so. Takes a while to copy. Select nav, then when you press eject it should prompt you that its not loaded yet...
