Page 15 of 21 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 204
Thread: RNS510 Australia V4 maps out ?
  1. #141
    Jun 2011
    N/A
    Any chance you a) have firmware version 3xxx and can confirm POI's work, and/or b) wish to mail/FTP me a copy =P?
  2. #142
    Jul 2010
    Quote Originally Posted by Klink1313 View Post
    Just an update. I went and picked up my map disc from the dealer yesterday. I was given a v4.1 disc so it looks like v4.1 is the new vw std
    The numbering sequence, doesn't look promising for working POIs.
    But I've been burnt before getting excited over the V4 map.
    So maybe V4.1 actually has the correct file structure?
    Actually can you outline the contents of the disk and post it up for a line by line compare?
    The file should be something like this: cdrom.toc in the root directory and you just need to open it in MS Word to view.
    Below is the content of this file for the V4 map:
    Continental Automotive GmbH
    I IC RD G SW NM DB
    Content
    Volume: CD_7360
    Date: 9.9.2010
    db: AUNZ(2009Q4)
    Area: Australia + New Zealand
    Supplier: Sensis
    Version: 505.99.981.84
    Customer: 1627387139
    Customer Info: VW
    Features: ZIP3kb - feaV10(VW)
    TPD: 2010065002
    SVD:
    TMC: no
    Phoneme: no
    DBAL: V005_015,V006_024
    Many thanks!
    MY11 Tiguan 147TSI (SOLD)
  3. #143
    Jun 2011
    N/A
    Was kind of hoping that 4.1, was 4.0 maps + POI's, hence the .1 , but then again newer maps might be better...
  4. #144
    Jan 2010
    North Shore
    I was told today that 4.1 has POI. Can't confirm if it's true though.
  5. #145
    Jun 2011
    sydney
    yes, 4.1 has POI, and that is what VW will be supplying from now.
  6. #146
    Jul 2010
    where do you get 4.1? not on ebay?
  7. #147
    Jul 2010
    All the previous versions (V3 & V4) had POI.
    It's not like they were missing or left off.
    But problem was they are only functional using 2XXX series FW.
    If stock units delivered from factory now are running 3XXX series FW or at least higher than 2840, then that's a good start!
    If the actual series of POI files on the disk are NOT stored in this directory: \TABLES\0\ and NOT with an .idx file extension ... only then do I see things looking promising.
    So my advice would be to wait and see!
    Hopefully Klink1313 is prepared to confirm this much (for now) for the greater of the community.
  8. #148
    Jan 2010
    North Shore
    Quote Originally Posted by rs73 View Post
    I doubt it. First time I saw it was yesterday.
    I wonder who will shell out the $400+ to get it legally?
  9. #149
    Apr 2010
    Judging by the contents of the 'Is the RNS510 worth $2500?' thread, I'm guessing not too many.
    If I stumble across it I might have a go, otherwise I'm fairly happy with what I've got (i.e. none of the new features appeal to me that much)
  10. #150
    Feb 2009
    Anyone have part number for the v4.1 disc?
