Originally Posted by
Superviza
So when you upgraded to 3810, did you do any intermediate upgrades to ensure you received the new Partitioning that is required by the new maps?
I'm still running 2720 on my C (star) unit, and apparently 4000 should be out soon so might look at updating to 4000 and the v4 maps
From what I've gathered so far, FW 3810 will partition, but FW 39XX don't. So yes ... you do need to load FW 3810 first to get the separate POI partition, if you want the higher Beta versions.
At this very moment, FW 2760 is the only one that will support POIs currently on both the V3 and supposed V4 map.
It will also read a modified map disk and importing pre-loaded destinations on a SD card.
So from a fully functional map perspective, stick to FW 2760 for now!
However Maverick has mentioned FW 2840 as the last official release in the FW 2XXX series.
But links are nowhere to be found at the moment!
MY11 Tiguan 147TSI (SOLD)
