Page 19 of 21 FirstFirst ... 91718192021 LastLast
Results 181 to 190 of 204
Thread: RNS510 Australia V4 maps out ?
  1. #181
    Aug 2011
    vic
    you have to leave the map dvd in for like half an hour or so. Takes a while to copy. Select nav, then when you press eject it should prompt you that its not loaded yet...
    Ah, see i got that message once, but then after a while i got a message saying that maps had been loaded, and it had an eject button on the screen. Still no good.
  2. #182
    Post some pics of the version and HDD info screens from test menu, see if there are any clues there...
  3. #183
    Aug 2011
    vic
    seems to have worked after I came back to the car tonight. once again I have another problem though. my Bluetooth audio streaming is no longer working. it allows me to press play and pause. and it works on my iPhone. but there is no sound the mdi and radio work. but bt streaming is not. any ideas?
  4. #184
    The Bluetooth volume by default is set very low from memory. Try going into setup->media and set bluetooth volume to medium or high (I think you have to already have the phone paired and Bluetooth streaming playing)
  5. #185
    Aug 2011
    vic
    hey had a look today. there was no Bluetooth volume option in media
  6. #186
    Aug 2011
    vic
    Quote Originally Posted by vraptor View Post
    tried reloading the firmware, and restoring iphone to factory firmware, and still nothing , no replies on vwnavi or golfmk5 either. bummer
  7. #187
    Firstly, I assume the iphone is paired with the RNS-510?
    Here is a demo of the steps..
    Volkswagen RDC-510: Bluetooth Audio Streaming - YouTube
    When the phone is paired and you start up ipod, there is like an arrow sort of icon down the bottom (don't have a bluetooth device with me so can't pair my phone to look at it and describe it better). You click on this and it allows you to select where you want to route the audio...
  8. #188
    Aug 2011
    vic
    Yep it's fully paired, phonebook and calls all works fine.
    And yep i knew this because it worked on the other firmware hahaha.
    it comes up with the option to play, pause, skip under media.
    pressing play does make the song play on the phone and pause likewise.
    The audio routing is set to the rns and not iphone, but there is no sound.
  9. #189
    Ok then not sure what the problem is sorry...strange.
    Plug it in via MDI? At least then the phone will charge
  10. #190
    Aug 2011
    vic
    yeah im going to work on an extension to get an ipod cable in the centre console, but still, its a bit of a pain!
