Results 1 to 10 of 10
Thread: Rns510
    Sep 2023
    Rns510
    Hi Guys,
    just having issues with the head unit asking for the navigation Dvd.
    I went into the menu to have a look at the HDD and this is what I found (refer to pics in link).
    Hdd shows volume size as zero megabyte and remaining space is also zero megabyte.
    Hdd is still formatted to Fat16.
    RNS510 - Album on Imgur
    Any help would be appreciated.
    Thanks,
    Gerard
    Mornington Peninsula, VIC
    More and more of the RNS510 look to be failing due to age; most have IDE HDDs.
    Try reloading the firmware on the unit: Firmware updates for RNS510 units in Australia/NZ
    And if that fails, an HDD replacement would be required. RNS-510 HDD replacement/SSD swap DIY
    Many people are upgrading the units with something that has a current map and many more features.
    Check out this thread for the top-of-the-line unit Discover Media retrofit
    Also, the RCD 330 is a popular choice.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Pacific Paradise QLD
    The latest and LAST map is $175 and I found that you cant reload the map thats in it over the top of itself has to be an older or newer one.
    Mindarie, Perth (WA)
    It looks like there is no map in the unit.
    @GerardR how long have you had the car? Did the RNS work ok until recently? What event occurred prior to the map not displaying (if any event at all - service, friend did a random VCDS scan maybe and 'fiddled' with the unit)?
    Needs more background info first.
    Sep 2023
    Thanks everyone for the advice and links.
    @FJ Steve - had the car for more than eight years, RNS worked without any issues until last week when it asked for the navigation DVD. Did vcds scan to enable secret menu and hence noticed the above issues.
    Quote Originally Posted by GerardR View Post
    did you get my PM?
    Sep 2023
    Quote Originally Posted by FJ Steve View Post
    did you get my PM?
    Thank you Steve for your Help.
    In the mean time I tried to reload the firmware (version 6276) hoping that it would reformat the hard drive and that would allow me to load the maps afterwards. Firmware loaded to about 6% of HDD update before failing with an error (pic uploaded).
    Imgur: The magic of the Internet
    From what I can gather on the internet this unit has already an ssd HDD installed.
    Now I have a non functioning unit asking for the SWL disc.
    Did you burn the disc at the lowest possible speed?
    SSDs can still fail; that drive is nearly 10 years old now. The part number for the 6xxx units should be 3c0a104005
    Pulling the drive out and checking its health in a PC would be an option to test it.
    Sep 2023
    Okay guys,
    just an update on the above. I replaced the SSD in the unit today and to my dismay I am still getting the same error message ( ERROR -HDDD - ERROR writing file).
    Does anyone have a copy of SW6276 ?
