Results 1 to 6 of 6
Thread: RNS315 camera into MIB unit
    Sep 2018
    Hi all, just successfully fitted the MIB STD2 PQ unit into my 2016 Amarok highline. It had the RNS315 head unit fitted with bluetooth, parking sensors and reverse camera.
    I used an adapter so everything is working, except the reverse camera as it didn't have an adapter and I can't seem to find one. The MIB unit doesn't have a pinout image on it, so kinda hard to know what I should even be looking for!
    Anyone have any ideas here? I'm hoping there is a cheap option on something like aliexpress
    Here is the connector without a home
    RNS315 camera into MIB unit-20180919_153759-jpg
    Here is the back of the units, RNS315 top left is where the connector was.
    RNS315 camera into MIB unit-20180918_165629-jpg
    And the back of the MIB unit
    RNS315 camera into MIB unit-20180918_165627-jpg
    And here's the RNS315 pin out
    RNS315 camera into MIB unit-20180919_080824-jpg
    Thanks in advance for any info!
    You can use an adapter:
    26 PIN RGB to CVBS (RCA) AV Converter for Volkswagen Factory Original Camera Output to Third Part OEM/After Market Head Unit DVD-in Cables, Adapters & Sockets from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
    However the quality isn't normally that fantastic due to the conversion of the video signal.
    The best option is to replace the camera with a composite camera.
    The easiest is to use a converter.
    Sep 2018
    Excellent, thanks for the reply.
    I came across this to get a signal into the MIB headunit, and the connector looks right, as I have that in the unit already with empty pins in those positions
    aliexpress connector link
    That then lead me to think could I pull the appropriate signal pins from the 26 pin connector. At a complete guess position 10-13 and 20-23 look to be camera related?
    As you mentioned a conversion of signal I'm assuming it isn't that simple
    No you can't just swap pins.
    Your factory camera is using RGBS which is a different signalling system than CVBS (composite video). RGBS uses more pins to minimise noise during transmission.
    Need to use a converter or replace the camera and wiring harness.
    Sep 2018
    Excellent, thanks! I've ordered some parts. I'll log back in and write up the results... in about a month when the parts arrive from China!
    Perth, WA
    Hi TMB99,
    Dragging up an old thread!
    I plan to do the same to my 2015 Amarok, it too has the RNS315. I’ve bought a second hand composition media (I’ll have to get CP deactivated). Do you have any tips? What did you end up doing with the reverse camera?
    Cheers,
    MCL.
