Yes, I've come across this.
You'll need to go back and check the wiring at the plug on the rear of the radio unit that contains the grey, green, and yellow wires. You'll need to configure them as per the installation instructions.
Also, it's worth checking the aux-in level, and that the EQ is turned of in your device.
However, the MDI will need to be coded.
