RNS Firmware upgrade to 3xxx
well...I bit the bullet and tried to apply FW3xxx (karmolds custom FW) this morning and each time I attempted it, it returned an Error 10306
Currently running the following: Del. Part. No. 1 T0035680 C
HW-Version H05
SW-Version 2760
SV SW-Version C_EU_9.242_t520
Running map 7492 (V4.1)
Any thoughts? Might go and pick up some new media and try that, however the current media (DVD-R) that I have used has worked successfully previously. Is anyone able to confirm that the unit quoted above is definitely a C unit and not a re-badged/flashed A/B unit? 'cos if it's a the latter, then FW2760 would appear to be as far as I can go, without going to the trouble of getting a new motherboard etc. And I'm not about to do that.
---------- Post added at 03:32 PM ---------- Previous post was at 12:24 PM ----------
investigating further.....here is the version.txt file from the 3xxx FW disc:
Software Loading CD for CP2 based units
(c) CONTINENTAL Wetzlar
CdTreeBuilder version 3.06 is used.
#CD
![Sticky out tounge](https://www.vwwatercooled.com.au/forums/images/smilies/tongue.png)
0 0 5 . 2 3 4 . 3 0 1
#DATE:2011-02-26
#Project: VWRNS
#Author: RoNe
#Steckbrief: C_EU_10.344_t190 C10/C6
#CommentStart:
This is a SWL CD for VW delivery.
#CommentEnd:
#Integrationphase: Delivery cw22/11 C10/C6-samples
#VwSwPartNumber:1T0035680D/1T0035680D/3T0035680B/7F0035680A/7E0035680A/1T0035680F/1T0035680G/3T0035680C/3T0035680D
#VwSwIndex:3970/3976/3978/3974/3970/3970
#AppsBuild:C_EU_10.344_t190 C10/C6
#CRC16:8db4
I note that my unit 1 T0035680 C is not listed in the Part number file. Guess this means it's not suitable to a C unit........
Thoughts?
---------- Post added at 03:42 PM ---------- Previous post was at 03:32 PM ----------
So...6 x DVDs & 1 x CD later.....no joy.
I reckon it's because the Part Number of my unit doesn't match the required info in the disc TOC file.
Bummer
