Ok lets explain it a bit better
The HDD holds the music and the maps The chip on the motherboard holds the firmware as in most devices.
The CD drive is what you use to insert the data for both the firmware and the maps etc.
You need the CD to work as there is no other way to load the info.
If you havent tried a new one do so. If it doesnt work you have a more serious problem and formatting the HDD wont fix anything except you will lose the maps and any music.
The HDD only has Maps, Music and POI files on it NO FIRMWARE
