Ok lets explain it a bit better
The HDD holds the music and the maps The chip on the motherboard holds the firmware as in most devices.
The CD drive is what you use to insert the data for both the firmware and the maps etc.
You need the CD to work as there is no other way to load the info.
If you havent tried a new one do so. If it doesnt work you have a more serious problem and formatting the HDD wont fix anything except you will lose the maps and any music.
The HDD only has Maps, Music and POI files on it NO FIRMWARE
thanks i understand it a lot better now.
i have ordered a new cd drive. I will let you know if it works. But if it doesnt work, is there software and a cable set to reflash the motherboard because i can let it do by a shop, so there has to be a way right?
No, you would need a new main board or the tools and expertise to get a eeprom dump from a good board and reflash yours on a bench
Sent from my HTC One M8 using Tapatalk
okay thanks i will use the cd drive on a another broken unit then in the future or resell it. But can you explain to me please what the tools called that i need
If you aren't already familiar with EEPROM readers, and soldering surface mount chips then you're better off buying a new mainboard or a whole new unit.
thanks for all the help kamold. I have soldered surface mount chips a few times so i wanna try make the unit myself. do you maybe have some info about eeprom which cable i need and software and maybe a guide or something
No there are no guides that I am aware of, there may be some people closer to you who have the experience, perhaps try on the vwnavi forums which are EU based.
okay i am going to try that. if somebody knows how the software is called and cable to flash the motherboard pls let me know. Thanks to everybody for the great help
