Results 1 to 10 of 13
Thread: RNS 510 stuck in german, Reverse camera and media unit not working.
    Dec 2009
    Sydney NSW
    Hey guys,
    This is an amusing, but quite annoying problem that cropped up last week.
    It seems like my rns 510 crashed last thursday night. When i started my car the next morning, the display read like it was "stuck" on an mp3 track on the hard drive, with no sound, or ability to switch tracks, or even modes or menus. I turned the car off, removed the key and waited a few seconds.
    When I started it up again, the menus had defaulted to German. Although I dont know how to read German, I did remember the the positions of the menus, so was able to find my way into the system menu, and the language selection option. However, if I select English, or even "automatic" the menu text will change to english, but the screen will display "loading desired language" then get stuck on "cannot load desired language".
    There is a cancel option on the screen, but it wont work. The only way to get out of this is to use the 3 button reset (RW, FF and star i think) to reset the RNS unit. It will then default back to German.
    In addition to being stuck in German, a more pressing issue is the fact that a large number of the RNS functions dont work at all now. For example -
    - the Reverse camera doesn't work at all. Mechanically I can hear it open in the tailgate, but no image displays on the RNS 510.
    - no audio works at all. Mp3s from the units hard drive, mp3s from a SD card, even aux input produce no sound whatsoever. I haven't tried a CD or DVD but imagine it will be the same story.
    - Radio doesn't work at all.
    - Navigation does work (in German) and I get a map display, but navigation directions no longer show up on the MFD between the tacho and the speedo. Additionally, audio information no longer shows up on the MFD either.
    Needless to say, Ive got a warranty service booked in for the Friday. The car is fairly new, bought last may, with around 8100kms on the clock.
    Just wondering if anyone else has had similar issues?
    Will let you know what the resolution is, regardless.
    cheers
    JW
    Mk VI GTI 2 door Manual, Park Assist, RVC, RNS 510
    Dec 2009
    Sydney NSW
    thanks dermot,
    I was never given an actual NAV dvd when i bought the car - everything was preisntalled when i got it. So I'll have to take it back to the dealer to get that done.
    I wonder if that will fix all the other issues like the RVC, audio and MFD syncronisation....
    JW
    Jul 2010
    Robina Gold Coast
    Quote Originally Posted by jwastrel View Post
    thanks dermot,
    JW
    Every one here knows you should get the DVD GPS Disc when you buy the car with the RNS510 installed, So ask them where your is , just say they must of over looked sending you your disc ,
    Dec 2009
    Sydney NSW
    Everyone here knows? Really? I didn't realise that DVD was supposed to be standard issue. RNS came factory installed - i was told the maps were installed at the factory too. I actually had to convince my dealer to install the V3 maps for me....
    Dec 2009
    Sydney NSW
    So I took it in and they replaced the entire unit. Warranty job, so free of charge. Everything works well, except - the new unit seems quieter than before. I usually had the audio level at around 20% for a comfortable listening volume. Now it needs to be at nearly 60%! The first 10% of audio level is virtually silent.
    I was wondering if there was a way to specify the RNS-510 base output levels? (hopefully via the system menu). Ive had a dig thru but can't find anything there.
    Dont really want to make another trip back to the VW service centre....
    IN2VWS Guest
    There is a few settings in vagcom that might help.
    I did notice a "Loudness" setting the other day, mine was set to 'on'.
    Dec 2009
    Sydney NSW
    Thanks IN2VWS
    Unfortunately I can't access that setting by holding setup (as i dont have VCDS). Probably got a version of the firmware that doesn't allow it. Looks like i will need to take it back to the dealer to switch the loudness on... Bah!
    cheers
    VW
    IN2VWS Guest
    My "holding the setup button" thing didn't work either. Had to switch that on with VCDS.
    These are the screens you can access from the sound setup menu screen.
    Dec 2009
    Sydney NSW
    ok now this is getting really annoying... After replacing the unit 3 months ago the thing has decided to fail again. Same problem - can't change the language from German back to English and the RVC is not working. For some reason Audio is working now though.
    2 units in 3 months - sounds like it isn't the unit itself. Another trip back to the VW service centre at Artarmon. Sigh....
    Seems like VW have still a way to go addressing their quality issues. I was hoping they had improved.
    Nov 2009
    Perth, WA
    Can't help with the language thing,
    But I installed a rvc and it also just wouldn't show up on the RNS screen.
    Got into the secret menu which has an indicator there to tell if the RNS knows it is in reverse or not. Turns out it didn't.
    A few guides online said that the canbus would need to be replaced, but I just tried upgrading my firmware from 2760 to 3810 and it fixed everything!
    So it might just need a firmware reinstall or upgrade.
    MY11 MKVI Golf Wagon 103TDI | Platinum Grey | DSG | RNS510 | MDI | Bluetooth |
