Results 11 to 20 of 21
Thread: RNS-510 SDHC support for larger than 32GB?
    No, keep holding down setup until you get to the second menu.
    Hw_vehicle is the field sorry
    Dec 2014
    Monaro, NSW
    Why you would want more than 32 Gb is a bit beyond me I have 6000 tracks on a card and they are only 18Gb
    My music collection is 80GB in size
    Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
    Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
    Dec 2014
    Monaro, NSW
    Held it down for one minute, twice, and no other menu appears. Presume it is not activated on my unit. I can tell you that it is a Revision P.
    Pacific Paradise QLD
    Quote Originally Posted by brettue View Post
    Where from?
    Your nearest friendly VW dealer would be a good place to start
    Quote Originally Posted by arcadelt View Post
    Did you buy it later because 2010 ones were nomally C or D versions. It didnt come up on mine till I upgraded the firmware to 4020 so that might be the trouble
    What size is the HDD?
    If its a new unit that has been retrofitted then it should support SDXC.
    Those micro adapters can sometimes be a bit hit and miss.
    Have you tried a full size SDXC card?
    Do what I said with the card and see what happens Ive got a couple of 64's and a 128 that all work when reformatted But you need that program to do it as Windoze wont format a card that big with FAT 32.
    As Kamold said adapters can be suss.
    Dec 2014
    Monaro, NSW
    Yes, Revision P installed on both my cars after purchase in the last two years.
    Dec 2014
    Monaro, NSW
    Yes, both were retrofitted. I do not have any full size cards, but will see what I can do. I'll also try reformatting with the software recommended by @Hillbilly. However, I think what you meant to say is that the RNS-510 can be a bit fussy, as nothing else I own has a problem with the adapter or the cards.
    Cards up to 32Gb are normally formattted as Fat32 Bigger capacity are either NTFS or Exfat and not all devices recognize them.
    Depends on what you are using them in whether they will recognize them or not.
    By changing the bigger ones to Fat32 they sometimes can be fooled into using the full capacity.
    The difference between the two formats is that FAT32 only allows file sizes of up to 4GB and Exfat goes much higher
