Hi mate. I haven't done this DIY but have read a bit about it as I've considered it in the past.
First things first you need to have the code for the radio, get your mate to get that from the dealer if he doesn't already have it.
There's also a ton of info already online regarding this.
Regarding the CanBus Gateway, I don't think anyone will give you a definitive answer as to whether your CanBus needs upgrading. From my experience, people usually say MY08 onwards has the correct revision, so you may need to change it, but you need a VCDS scan to determine that for sure.
Seeing where you're based, I would get this guy to sort you out with the required parts and installation if you're unsure about it:
Other Ads from Vincent | Gumtree Australia. I have spoken with him before, gets back to you quickly and if I was in the state I'd have gone with him.
And here's people talking about his work and the installation: RCD510 Installed [Archive] - VWGolf.net.au - Australian VW Golf Forum
I can't see the new CanBus currently listed but I would just ask him about it as he usually has it listed. They usually cost $80-$100 and he charges $100 for a CanBus installation it I think.
You will also obviously need a GPS antenna to make the GPS work. Generic antennas seem to do the job from what I've read, doesn't have to be VW specific. they can go under the vent in the top of the dash or just on the dash. have seen both ways done.
Not sure about the antenna adaptor, here's a RNS510 installation DIY for you to read:
DIY - RNS510 Install
In short, the physical install of the Head Unit is easy enough, it's the ambiguity around the CanBus where you'd need someone to help determine which revision you have, and if a new one needs to be installed, the new part needs to be coded to your car before it will work.
Hope I've been of some help - For those that have installed, If I've given the wrong advice feel free to let me know and I will correct it.
Reason: Added correct link to DIY
Mate thanks for taking the time to reply, appreciate it. Yeah seems to me that the canbus will be the biggest issue, I'll have a chat to the guy you linked. Picked up the antenna adapter today so that's all good. Just have to figure out this Canbus issue. Hopefull all goes well. Thanks again for the reply.
- You may not post replies
- You may not edit your posts
Forum Rules
