Results 1 to 10 of 11
Thread: RNS 510 Problem
    Sep 2010
    RNS 510 Problem
    I've had an RNS510 for a little over a year now in my Passat. Just recently, it is constantly getting lost - saying it's off-road when it's not, or saying it's on a different road. Sometimes up to about 500m out. Any ideas ? Would a software refresh fix the problem ? Many thanks.
    Dec 2009
    Kew, VIC
    My first thought would be to check the antenna and its connections, then the power (connections, and voltage at the input.)
    You could try reloading the maps, but it's unlikely to be the problem.
    Jul 2011
    What navigation version do you have installed?
    Sep 2010
    Version 2760. There's been no issues before now, and it's only an intermittant problem. If I reboot the unit it generally fixes itself.
    Jan 2010
    City, NSW
    If it's still in your 3 years warranty period then DRIVE TO THE DEALER ASAP!!!
    Nov 2010
    Burpengary, Queensland
    Quote Originally Posted by wandersen View Post
    Do you have an in-car video camera?
    I had the same problem with mine, I tried rebooting and it would be OK for a short time and then revert to acting wierd again. Problem was interference from a screen mounted video camera I had installed, removed the camera and the RNS worked fine.
    Sep 2010
    Unfortunately I had itr installed after I bought the car (more than 12 months ago now). Purchased the unit from OS.
    Hey Wandersen any good news update ?
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Sep 2010
    No, it's actually gotten worse. I've checked and it's not receiving any GPS signal at all (hence being very inaccurate). I've ordered a new GPS antenna so hoping that will fix things. I don't particularly want to pull my dash apart to pull it out - but then it seems like an easy enough job, I guess I should do it myself !
    Jan 2007
    brisbane QLD
    a new GPS antenna fixed the issue for me. It was not picking up any satellites as well (a few weeks after I moved it from another car)
    Main Dub:
    2010 Crafter Hanover Bus
    1956 Type 1
    2015 vRS wagon black on black
