Hi All
When ever i start the car and view the GPS co-ordinates it thinks it is in germany. Anyone know how i can sort this out.
website: www.my-gti.com
I have the c version with firmware 2660, also get error report from can bus 1044 dont know if has anything to do with it.
Have you tried going for a drive?
Assume you have the AUS maps on it?
Unfortunately you have the dreaded Regensburg syndrome. Better than swineflu but probably just as annoying.
It is more of a glitch . You can try updating your firmware but it seems hit and miss according to others.Some have fixed the problem by downgrading their firmware.I am not suggesting you do this just reporting what i have read. Go over to vwnavi.com for more info.
Looks like i might have to upgrade the can bus gateway just dot know which version....... or change the firmware to a lower spec
Hope this extra bit of information helps;
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K08C03022B
Coding: ED807F06400202000003
Shop #: WSC 01357 011 00200
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 13
Mileage: 25366 km
Time Indication: 0
Date: 2011.14.03
Time: 23:49:02
Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
Part No SW: 1T0 035 680 C HW: 1Z0 035 680 A
Component: RNS-MID H05 2660
Revision: AB001001 Serial number: SKZ6Z7J5062007
Coding: 040004020400008100
Shop #: WSC 00875 272 21183
ASAM Dataset: ------------------------- ------
1 Fault Found:
01523 - Microphone for Telephone (R3![]()
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 236
Mileage: 25518 km
Time Indication: 0
Date: 2011.14.05
Time: 19:45:43
I've always been deeply suspicious about the Regensburg syndrome being a problem with the owner (or dealer) not the RNS510. So here goes with my experiences - may be totally wrong of course...
When my Tig was delivered, dealer had loaded the Aussie maps, unit was picking up lots of satellites, but map was blank. Dealer puzzled. Eventually told me to drive around for a bit and it 'would fix itself' - which it didn't.
Noticed it kept changing its Lat/Long co-ordinates from a position that was clearly in Europe (which is why the map screen was blank, since Europe isn't part of Australia. Not lately anyway).
So - entered my home address (which satnav was quite happy to look up, since it had the Aussie map) and saved it as the unit's 'Home' address. Problem solved, as that wiped out the stored Lat/Long (which is, of course, the factory location).
Dealer rang next day to ask how things went - told him the fix - long silence as he had a 'doh' moment. Recovered by saying 'yes, we usually save the customers home address in the unit for them, and so never have that problem' (Ha!)
So - I recommend you just delete ALL saved locations in your RNS510 and see what happens...
MY10 Tiguan 125TSI + APR 1, 6spd manual, Cherry red, RNS510, panoramic roof, park assist, towbar, mats
Mine fixed itself after going for a drive when i loaded the new firmware a while back.
Initially it just displays a white background but should come good.
Depends how old the car is etc as it may need the can gateway upgrade by the sound of it.
I have had the unit for about two weeks so should have sorted it self out in regards to drive around. I will give the save my location ago
