Results 1 to 8 of 8
Thread: RNS-510 with Parrot CK3000 low volume problem
    no coding done. What coding would be required? i thought that would only be for the factory bluetooth?
    how do i reset the unit? also what do you think this achieves? (just curious)
    Current: 2017 Passat 206TFSI R-Line
    Previous: 2007 Jetta TFSI DSG
    19" Shadow Chrome Omanyts | R-Line Fog Light Grills | FK StreetLine Coilovers | Sunroof |
    Votex Bodykit w/ Gunmetal Diffuser | Parrot Bluetooth & Steering Wheel Kit | OEM Xenons
    Mindarie, Perth (WA)
    if you are running the BT thru the RNS (and as such...through the vehicles CANBUS) it would be my guess that a CAN Module needs to be adjusated via VCDS settings/cable. Others with experience with BT installs may know the answer to this.
    Reset of the RNS is achieved by pressing "<" + ">" + "i" (or the button at top right hand corner next to "Eject".
    Like a normal PC, that requires a re-start when installing new software/updates, the RNS requires a reset whenever adjustments/additions are made.
