I've had this before, I can't recall off the top of my head, but there is an option to select in VCDS that allows both on the screen at the same time.
edit:
Guide for VCDS coding for RVC retrofit
After fitting a reverse camera (low line ) to a Rns 510 P with f/ware 5274 it is not displaying the optical park on the left of the screen when reverse is selected and the rear camera is displayed. I have to select the camera each time I use reverse . The optical park comes up full screen with the camera button as the default display. Can this be changed ? i do have access to a vcds. Thanks
Passat MY12.5 TDI.
edit:
You need to go into '10' parking aid and tick the box for reverse camera installed...after that the camera with auto come on the display first.
DARKHORSE DEVELOPMENTS
BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. 0420839266
BRISBANE/GOLDCOAST/IPSWICH
www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
Thank you That was it!!
Passat MY12.5 TDI.
