Page 23 of 32 FirstFirst ... 132122232425 ... LastLast
Results 221 to 230 of 315
Thread: RNS 510 Navigations available from Aussie dealer - www.JKU.com.au - free postage
  1. #221
    Sep 2012
    Hi,
    I live in Brisbane but I am able to travel to the Sunshine Coast , what would be the cost of Rear Camera & OPS system for MY12 Golf GTI?
    Thanks
    2012 Golf GTI - stock
  2. #222
    Jun 2012
    Maroochydore, QLD
    Hi Cam,
    RVC is $600+GST install is $350+GST
    OPS is 500+GST install is $500+GST
    painting of the sensors is 90+GST ( you get 100 ml of paint as a touch up with it as well)
    Quote Originally Posted by Cam89 View Post
    Hi,
    Thanks
  3. #223
    Jun 2012
    Maroochydore, QLD
    V-TECH ECU RE-MAPS & CHIP TUNING available for FORUM MEMBERS only starting at $750 (for older cars)
    We offer professional CHIP TUNING for your vehicle. Complete re-map suited personally to your car starts at $750. We CHIP most makes and models and specilise in VW AUDI BMW & MERCEDES.
    Contact us for the example graphs for your vehicle. V-TECH is a leading EUROPEAN Tuning Company with over 20 years of exeprience.
    DIY with a fault reading Flash Computer at additional cost
    RRP: $1500+GST
    WaterCooled member discounted price: $1250+GST
    Tunes available:
    Stage 1 with emphasis on power
    Stage 1 with emphasis on fuel economy
    Stage 2 with emphasis on power
    Stage 2 with emphasis on fuel economy
    Stage 3 with emphasis on power
    Why choose ecu chip tuning over plug-in modules??
    1.
    Because rail pressure modules/pulse width modules can only increase and decrease fueling.
    To make more power using a chip, you need to inject more fuel, which means increase fuel use.
    Pulse width can also modify injectors delay, but they cannot advance injection correctly.
    2.
    Rail chips cannot overcome ANY torque limiters in the ECU. Period.
    Increase fuel as much as you like, they will meet a "brick wall" which they cannot get around.
    3.
    ECU tuning actually can reduce your fuel use substantially and is backed up by ACTUAL dyno figures and real world figures.
    4.
    We edit over 800 cells in the ecu. The maps are 3 dimensional. This is why we can actually make the car feel completely different with an ECU tune. We all have heard the stories of how "chips" don't even make a noticeable difference in performance but will increase fuel consumption. Not all "chips" are the same, but most do the same thing. ECU tuning is completely different. We do not trick the ECU.
    Why does ECU tuning tend to make a more driveable vehicle and make more power and save fuel at the same time?
    This depends on how you drive too. The engine management is a flowing 4d canvas with lots of variables. We edit the ECU logic for as many situations as we can envision. Overall you should feel a completely fluid transition from power to cruise and back.
    What do we change?:
    -Drive-by-wire pedal feel
    -Injection angles
    -Fuel rail pressure (Never more than 2% increase over stock, unlike plug-in chips)
    -Torque limiter for 1st and 2nd gear
    -Torque limiter for remaining gears
    -Torque governor
    -Torque request warm
    -Torque request cruise
    -Torque request non-cruise
    -EGR (Exhaust gas re-circ) (We can switch this off for Off-road/track cars)
    -DPF management (We can switch this off for Off-road/track cars)
    -Boost levels (We usually keep the boost around stock unless requested)
    -Gearbox controls (Auto)
    -Turbo dynamics
    -Warm up fueling (Usually leave stock settings)
    Physical changes?
    We keep the engine bay looking stock. The same goes for your ECU. Everything used it VW parts, screws so noone can tell that the car has been chipped. We also use Thermo Paste which no other Chip Tuning Company in SEQ uses and it is vital to seal the ECU with it.
    Can we remove the tune? What if I lose my tune due to VW ecm update?
    We re-instate lost tunes usually at no cost. Tunes are only lost if VW make an update to engine management. This usually happens only in the first 1-2years of releasing an engine setup. This period has passed and I don't expect further updates to engine management from VW.
    How safe are the tunes?
    The Amarok uses a bosch 4.9 wideband air fuel sensor for onboard tuning. The Amarok pulls/adds up to 25% fueling to keep in the pre-determined fueling we set. We aim to keep AFR's above 18:1 to stop overheating issues of the piston crowns.
    The Amarok also self-monitors EGT's (Exhaust gas temps) if they get high, power/fuel is reduced to keep the engine safe.
    What this means is, the engine management should never let the engine get into a dangerous situation as long as all sensors work correctly. This engine has been tested to over 30psi boost by us and we are confident that keeping to our low targets of boost for stage 1 and stage 2 tunes will keep engines safe.
    What are common problems with tunes?
    Increased clutch wear
    Increased engine mount wear
    Increased tire wear
    Why do some tuners have issues tuning the Amarok?
    These fall into 3 categories,
    1. Those who treat a Bosch ecu logic with say Japanese style tuning. (Does not work!)
    2. Those who don't edit the ecu correctly, due to the variable firmware from vehicle to vehicle. (There's about 60 different versions of the Amarok ECU so far! - Get it wrong and you could cause damage or get no tuning result!)
    3. Those who don't edit the torque limiters and just add a heap of boost/fuel but make bugger all power/difference to stock.
    We don't have these issues as we actually write some of the files for Bosch OEM ecu's aswell! We have bosch motorsport heritage and experience.
    Its one of the hardest ECU's to edit and only a handful of companies can see the entire ECU contents for values.
    Do you offer a trial of the tune?
    We offer a 14 day money back if you want your ECU returned to stock in that period.
  4. #224
    Aug 2013
    Newcastle,NSW
    Hi,
    How much for an High line Badge reverse camera and OPS sensors front and rear(already have a RNS-510 ),plus install in Sydney?
    Thanks
    2011 Golf GTI
  5. #225
    Jun 2012
    Maroochydore, QLD
    Hi mate,
    OPS full is $700+GST
    RVC High for Golf GTI is $1000+GST
    You are looking at about $800 to have it all installed over the course of 2 days in Sydney. Especially OPS as it is a big job.
    This does not include paiting of the sensors which you can DIY
    Quote Originally Posted by Vards View Post
    Hi,
    Thanks
  6. #226
    Aug 2013
    Newcastle,NSW
    Quote Originally Posted by liquidforce View Post
    Hi mate,
    Thanks for the quick reply, whats the best way to place an order with you guys? How much for the painting of the sensors?
    2011 Golf GTI
  7. #227
    Jun 2012
    Maroochydore, QLD
    hi mate,
    website is the best place. www.JKU.com.au
    https://jku.com.au/vw-parts/rvc-came...5n0907441.html
    https://jku.com.au/vw-parts/optical-...r-vw-golf.html
    We can paint the sensors for you at additional $80+GST if required. We have a paint shop opposite our workshop
    This will get you about 100ml of touch up paint as well. Cost price
  8. #228
    Aug 2013
    Hi,
    What would be the cost of Rear Camera & RNS510 plus install for MY14 Tiguan in Adelaide?
    Thanks
  9. #229
    Jun 2012
    Maroochydore, QLD
    Hi mate
    Thank you for your question
    Gear:
    RNS 510 P - $1300+GST - new (savings of $200) for forum members
    Camera low - $410+GST
    Camera High - $850+GST - dynamic lines+VW module to work with steering angle sensor
    Install at around $500 at flagstaff hill
    We would recommend camera with dynamic lines. It makes reversing a bliss and is installed onto likes of A8 and A7 also as an optional extra.
    on how highline camera works
    We also do Bi-Xenon headlights for tiguan
    They swivel up and down and left and right like on this video
    They are on special at a cost price at the moment.
    Generally speaking it is better to order them from the factory but if you have already placed an order it might no be possible.
    Congratulations on the purchase - we love working on a Tiguan across Australia
    Quote Originally Posted by loran View Post
    Hi,
    Thanks
  10. #230
    Jun 2012
    Maroochydore, QLD
    RNS 510 on special for forum members - pay for version H(obsolete) and get version PRNS 510 Navigations available from Aussie dealer - www.JKU.com.au - free postage-9edq-jpg
