Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: rns-510 navigation by voice
  1. #21
    'B' version in the Columbus is equivalent to 'C' in RNS510, they are both LED screen versions.
    I can't remember either, but I'm pretty sure once we had compatible maps installed (v5 and up) that voice command for navigation entry worked with firmware 39xx and up.
    I checked mine yesterday and voice entry still works with v6 maps and 5238 firmware.
    If the mic is not plugged in at all (ie only wired to the BT unit) then you wont get any commands to work at all, cant select radio, media etc it will just say, 'Pardon?' after you press the voice button. Only nav not working is a coding/compatibility issue only.
    Refer to Maverick's instructions for retrofitting of mic, it has the coding instructions also:
    Volkswagen RNS 510 Microphone Connection for voice control | my-gti.com
    note the byte 7 coding...bit 0 should be selected, bit 1 should be delselected. Then bits 2 and 3 should be deselected to allow voice and screen input whilst moving. Lastly bit 7 should be enabled in all recent cars that support it, this puts the navigation instructions in the MFD.
  2. #22
    Pacific Paradise QLD
    Have gone and had a play and YES IT WORKS in navigation.
    However it seems it would be quicker to enter the info manually as it didnt understand the street I was trying to input.
    Not to worry will play further and doubtless it will sort out somewhat.
    So to confirm It works on my C unit with 4120.
  3. #23
    Jul 2010
    this is the version i have.
    3T0 035 680 A
    HW: H41
    B 26.08.2010
    i'm running 412x with v6 maps.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  4. #24
    Re: rns-510 navigation by voice
    Yep consider it a C unit in terms of vintage as that's how it lines up with the Vw parts.
    Sent from my HTC One using Tapatalk 2
  5. #25
    Jul 2010
    Might have something to do with your hillbilly accent Hillbilly?
    MY11 Tiguan 147TSI (SOLD)
  6. #26
    Quote Originally Posted by aussietig View Post
    Ha ha very funny
    Perhaps its cos I speak English and not Austraaaaain
  7. #27
    Is it something like this?
  8. #28
    Jul 2010
    Or this perhaps?
  9. #29
    Mar 2009
    Melb
    Mine works only if I had voice tagged a saved address.
    Tig 162 R-Line; Audi TT
