Sounds like there is something stuck in the fan, or the fan has failed.
Dismantle it and check it's the fan then replace
Hi I am first time to write in here, I had Jetta for about 3 1/2 years. About a week ago when I unlock my car it start make noise about 2-3 seconds. Now seems longer, this happen when I open car door, unlocked car or start engine. I need advice about this issue,
VW Jetta RNS-510 noise - YouTube
this is youtube link, about explain what happened.
I look forward some advice
Thanks
Thank you for reply, I have no idea how to do itif I leave it, is it going to threatening damage of the car? cause my annual service comes up in 4 month.
It looks like its an RCD 510 and not a NAV unit Leave it turned off if you are worried about it
I turn it off but that noise still present,
In that case turn your heater or aircon off and see if thats what it is rather than the radio. Did you turn the radio off with the left hand knob
Does the RCD 510 (shown in pics above)actually have a fan as all exterior shots except one Russian one dont show fan shaped holes in the case
If it's the A/C fan then it's a fair chance it will have leaves in it that have entered through the vents in the plenum chamber.
Do you park under trees that drop leaves?
If so you may need to access/remove the fan in the passengers footwell to retrieve them but in some cases you can get at them through the fan grill with pointy nose pliers.
Cheers dave
Turn the radio off and see if the noise is still there ,as like weonarok said it could be some thing completely seperate to the radio ?
