Results 1 to 10 of 216
Thread: RNS-510 HDD replacement/SSD swap DIY
Threaded View
  1. #10
    France , Lyon
    hdd fail
    Hello and thank you all for sharing with us your knowledge.
    I will itemize all of my history because I dry a little.
    I bought a bit ago rns 510, 1T0 035 680 hw 0520 down motherboard and I replaced a motherboard firmware B version HW11 3980 which is happening in D.
    It works very well indeed, the concern is that I've realized that my Hitachi HDD is faulty, not detected in media and on my pc.
    So I installed another hdd ide 2.5 inch a place and that, it is detected, I can even copy mp3.
    My problemis that I wanted to format my new hard drive to install v9 card.
    I do not own the image of the old hard drive and it is impossible for me to gain recognition on my pc because it tells me not initialize status.
    When I load any version of that 1100 or 2660 I authorize the downgrade on the RNS 510, the update starts, but I do not see the gateway appear in the progress bar or the hosts or APPS or HDD,
    RADIO, MPEG only SWL bar starts, and the final installation of the unit tells me error ecu.Txt error hw version of I precise that when I run the recovery cd, my car radioback in operation, but still with the non-partitioned HDD.
    Another problem noted yesterday, my car radio isnot recognized in my vehicle, I said, no sound, not to tune, however thenavigation function works very well on the DVD only
    And VCDS along coding gets error 31 request out of range, even in the two bytes missing.
    I precise that my new HDD is format the drive to ntfs and I create a ntfs partion in thisproblem arises there also.?
    There was there a firmware that solves this problem?
    My new HDDis to blame?
    Thank you for caring about my problem.
    Thank you very much.
