Page 6 of 22 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 216
Thread: RNS-510 HDD replacement/SSD swap DIY
  1. #51
    Jun 2009
    Western Sydney
    You can replace the drive in any model, so yes, but you need to use the right type of drive. I don't know of any 120GB drives, only 128GB. Check the first page for HDD specifications.
    And no, it won't make the processor any faster, but it will improve the speed of the scrolling through the music menus. The speed of the unit is limited by the units processor, not the HDD.
    Hope that helps!
  2. #52
    Apr 2012
    Denmark
    Where is the HDD pic.. http://i44.tinypic.com/156wtvb.jpg
    Thanks for a fast reply i appreciate it alot
  3. #53
    Jun 2009
    Western Sydney
    Let me check. I will get back to you.
    Edit: It should work, but it's not an SSD drive, and it's not a shock proof drive like the standard RNS-510 drives. I would advise against it, but it is your decision. It is more likely to fail due to vibration, and you won't see any of the speed improvements you would with an SSD.
  4. #54
    Apr 2012
    Denmark
    Can you recommend a SSD drive?..
    I'm going to take a chance with the old drive
  5. #55
    Jun 2009
    Western Sydney
    Sure…
    128GB KingSpec 2.5" PATA/IDE SSD Solid State Disk (MLC Flash)
    Although I recommend the 64GB version of this model as it is better value.
  6. #56
    Apr 2012
    Denmark
    Awesome thanks 64GB it is then
  7. #57
    Nov 2009
    Hi John, fantastic thread. Is the destination entry quicker with the ssd?
    Volvo S60 RD T6
  8. #58
    Jun 2009
    Western Sydney
    Thanks. I wouldn't think so, although I've never found its speed all that limited to be honest. Either via the keypad or voice control. That would be more processor dependent.
  9. #59
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by johnc View Post
    Exploded Component Overview:
    It has been a while and I should say this unit is still going strong with the SSD in it. So thanks again John for the install.
  10. #60
    Jun 2009
    Western Sydney
    Cheers Mick. Thankfully one of them is. Ben's unit it being a right ****. Funnily enough, it's the only unit I've done that doesn't have an SSD.
