Results 1 to 10 of 216
Thread: RNS-510 HDD replacement/SSD swap DIY
Threaded View
  1. #2
    Jun 2009
    Western Sydney
    STEP 6
    RNS-510 HDD replacement/SSD swap DIY-arnshdddiy-step6-jpg
    Remove the 1 x T8 screw from the rear of the heatsink. Then remove the 2 x T8 screws which are down inside the heatsink. The two arrows in the picture highlight their location. This is one of the reasons behind the long reach T8 driver.
    STEP 7
    RNS-510 HDD replacement/SSD swap DIY-arnshdddiy-step7-jpg
    Remove these 3 x T8 screws from the rear of the heatsink. Then remove the 2 x T8 screws which are down inside the heatsink.
    STEP 8
    RNS-510 HDD replacement/SSD swap DIY-arnshdddiy-step8-jpg
    Drop down the rear cover plate in the same way you removed the top cover plate in Step 2. Disconnect the cable for the fan and remove the plate from the hinge.
    STEP 9
    RNS-510 HDD replacement/SSD swap DIY-arnshdddiy-step9-jpg
    1. Remove the 1 x T8 as indicated.
    2. Carefully lift the card (red highlight) in an upward direction. The card is plugged into the upper circuit board and may resist a little. See Step 10 to see what the card sits in. Just try to lift it evenly, and also pay attention to the opposite end of the card as is needs to be guided up between 2 metal prongs. These prongs can be seen in Step 11.
    STEP 10
    RNS-510 HDD replacement/SSD swap DIY-arnshdddiy-step10-jpg
    1. Remove the 3 x T8 screws from the board.
    2. Straighten the 2 tabs (as shown) in order to lift out the upper circuit board. Lift it out and pay attention to any places where it may catch on the existing frame. It needs to be done at a bit of an angle to clear the 4 screw tabs towards the rear of the left and right cover plates.
    STEP 11
    RNS-510 HDD replacement/SSD swap DIY-arnshdddiy-step11-jpg
    Once the upper circuit board is out of the way, you need to remove the 1 x T8 from the HDD mounting cover bracket. You can then carefully lift the HDD directly out of its plug in an upward direction.
    STEP 12
    RNS-510 HDD replacement/SSD swap DIY-arnshdddiy-step12-jpg
    Once removed, undo the 4 screws from the HDD mounting plate and replace it with your new drive. I’ve replaced this one with a 64GB 2.5” SSD IDE PATA MLC. Depending on your firmware version, this will either give you a 40GB music drive (2 partition firmware) or a 30GB music drive (with new 3 partition firmware). Remember to remove the jumper on your new SSD drive. You cannot insert the HDD with a jumper in place.
    SSD drive specification
    RNS-510 HDD replacement/SSD swap DIY-arsn510ssdspec-jpg
    STEP 13
    RNS-510 HDD replacement/SSD swap DIY-arnshdddiy-step13-jpg
    Reverse the procedure and you’re done. Double check all of the ribbon conenctions along the way. Plug it into your car, load your firmware+maps and check that everything is working as it should.
    After it's all back together and plugged in, you'll need to install the firmware and then your maps to get the drive working.
    After some recently developments by kamold, it is now possible to change the size of the partitions on the drive. For more details, visit: How to re-partition the HDD in your RNS510
    RNS-510 HDD replacement/SSD swap DIY-kamoldcomesgold-jpg
    Enjoy.
    Last edited by kamold; 27-02-2015 at 03:18 PM. Reason: Added pics back in which had expired
