Yes I have Setconfig and it is very useful...as long as I have the unit on my bench.
[QUOTE=Transporter;1301103]The copy won’t help you. You need the dongle as well as the program.[/QUOTE
NEverthess could you send me a copy ? I can cope with usb dongle. Thank you very much .
Best regards ( fwi98@yahoo.fr)
Emmanuel
The software needs the cable. It is licensed and protected by a key and serial number.
You can see if Josi has any left it is not free software.
hello
i'm french so sorry for my English,
I tried the tuto, but I create a clone of my HDD to the SSD with Acronis true image
My RNS510 no recognise my SSD, media is blocked " starting in progress (in french)" and the navigation does not work
If i install the origin HDD, everything works again
Help me please !
You need to use a factory firmware cd to reload firmware and format the new hdd
But when i install SSD. Media is blocked. I use the firmware 5274 but my rns510 does not recognise. My factory firmware is 4120. If i tried with firmware 4120 it’s works ?
