Page 20 of 22 FirstFirst ... 101819202122 LastLast
Results 191 to 200 of 215
Thread: RNS-510 HDD replacement/SSD swap DIY
  1. #191
    Yes I have Setconfig and it is very useful...as long as I have the unit on my bench.
  2. #192
    Jun 2019
    France
    Ok thanks . Do you think it could be possible for you to kindly send me a copy of this tool ? , so I can also test and config my unit .
    Best regards
  3. #193
    Adelaide hills, SA
    Quote Originally Posted by Fwi98 View Post
    Best regards
    The copy won’t help you. You need the dongle as well as the program.
  4. #194
    Jun 2019
    France
    [QUOTE=Transporter;1301103]The copy won’t help you. You need the dongle as well as the program.[/QUOTE
    NEverthess could you send me a copy ? I can cope with usb dongle. Thank you very much .
    Best regards ( fwi98@yahoo.fr)
    Emmanuel
  5. #195
    Jun 2019
    France
    [QUOTE=Fwi98;1301135]
    Emmanuel
    I see USB connexion is made via UART interface of the RNS .
  6. #196
    Jun 2019
    France
    Hello , i renew my wish : is it possible for you to send me a copy of SetConfig for RNS ( with monitoring function) ? It would be very kind of you and it would be very helpful for me to repair my unit .
    Thank you very much
    Best regards
    Emmanuel
  7. #197
    The software needs the cable. It is licensed and protected by a key and serial number.
    You can see if Josi has any left it is not free software.
  8. #198
    Sep 2019
    France
    hello
    i'm french so sorry for my English,
    I tried the tuto, but I create a clone of my HDD to the SSD with Acronis true image
    My RNS510 no recognise my SSD, media is blocked " starting in progress (in french)" and the navigation does not work
    If i install the origin HDD, everything works again
    Help me please !
  9. #199
    You need to use a factory firmware cd to reload firmware and format the new hdd
  10. #200
    Sep 2019
    France
    But when i install SSD. Media is blocked. I use the firmware 5274 but my rns510 does not recognise. My factory firmware is 4120. If i tried with firmware 4120 it’s works ?
