Page 16 of 22 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 215
Thread: RNS-510 HDD replacement/SSD swap DIY
  1. #151
    Jan 2018
    Azerbaijan, Baku
    Firmware for SSD starts from 6xxx
  2. #152
    Quote Originally Posted by zeko1024 View Post
    Yes it reads Ok with the old HDD. But I will try another CD to be sure. I must start from the firmware 1100 ?
    No just load 5238
  3. #153
    Quote Originally Posted by teymur88 View Post
    This is an aftermarket SSD.
    It's a pata device connected via the pata interface, not hard wired to the board like a factory ssd system.
  4. #154
    Jan 2018
    Azerbaijan, Baku
    Understood. Thanks for clarification
  5. #155
    Feb 2018
    France
    Maybe I missed something but where is written in the originat post than the firmware for SSD is the 5238 ?
    My RNS is in 1100 firmware, and i can't update the firmware to the 5238 version because of the broken HDD. So I suppose I can't swap the HDD for a SSD in my RNS 510 in its current version...
  6. #156
    It is not specific to SSD.
    It's just the latest available firmware for your unit.
  7. #157
    Feb 2018
    France
    I gave up... There is nothing to do, I have always the same issue when I put the SSD.
    I ordered an original Hitachi HDD and i'll try again with this new one. Thanks for your help.
  8. #158
    May 2018
    London, UK
    Followed all the great advice to upgrade SSD. I also added a new power board.
    only problem is that the following two problems have arisen (they weren't there before the upgrade):
    1. no sound from BT module (the parrot style one that sits on dash)
    2. unit switches off after 30 minutes
    any advice would be extremely welcomed
    thanks
  9. #159
    Quote Originally Posted by bob76 View Post
    thanks
    What firmware version did you install?
    What version was installed prior to the SSD install?
    Why was the power block replaced?
    When you say no sound from the Bluetooth module please be specific - caller's voice? Your voice? Streaming music?
  10. #160
    Does the device ask for a code when reinserting it (into the same car)?
