Chuck it out as its well past use by date and development has long discontinued. Up to date maps are no longer available for them either.
Far better to spend money and time installing a later model unit for which stuff is still available
Printable View
Followed the diy step by step, first of all amazing guide! I installed new 80gb hard disk and now the unit's cd drive does not want to work.. only when i unplug the new hard disk and leave it unplugged or plug back old hdd back in will it work :/ Any solution??
Check the jumpers on the HDD; if the drive conflicts with the DVD drive on the same IDE bus, that will cause this.
Set the drive to CS or cable select if possible.
"Remember to remove the jumper on your new SSD drive. You cannot insert the HDD with a jumper in place."
Apologies if this has already been answered.
What size SSD do I need? Can I get away with a 32GB PATA?
32GB should work, the units came with a 30GB originally, I have had good luck with this adaptor in the RNS850 in the Touareg Server Busy
