Should have done your homework!
But admittedly, my warnings are scattered all over the place and not a sticky!
E.g. http://www.vwwatercooled.org.au/foru...e-58954-2.html
http://www.vwwatercooled.org.au/foru...tml#post718610
There's no working POIs with our crappy Australian maps (including 7360 V4 map)!
If working POIs is important to you, then you need to rollback SW to version 2760 or lower.
Otherwise, hope and pray (like everyone of us) that the next map version has the correct POI file structure that's compatible to 3XXX series SW.
Anyhow I'll repeat my warning again here:
POIs will only work on Australian maps (up to and including version 7360 or V4), IF you're running SW version 2760 or lower.
In other words, don't buy RNS510 units pre-installed with higher SW versions.
Ask them to re-install the older 2760 version for you!
MY11 Tiguan 147TSI (SOLD)
