The second message was the approval to load.
If you ok that it will load the custom image. You just chickened out![]()
I'm confused.
Thought I'd try John's suggested method at top of thread, a few error messages, few reboots, then this:
Rebooted with <SETUP>+<MIC>+<EJECT>, RNS-510 won't boot, has error message that it wants the SWL disc, insert disc then this:
I chickened out and cancelled, because there had been so many error messages getting that far and I didn't want to end up with a bricked RNS-510.
Maybe it would work if I tried again?
My RNS-510 does not have setup menu enabled. So I presume the correct steps to follow are per FJ Steve + edits:
Setup, Eject and Star, forces the unit to go into a FW downgrade mode when next you insert a FW disc. To do this right....
1. open car, leave keys in pocket.
1a. start up the RNS by pushing the volume button in, wait for boot to finish?
1b. force downgrade mode by pressing all at once <SETUP>+<EJECT>+<MIC>
1c. wait...??will reboot automatically or needs to be restarted menually
2. start up the RNS by pushing the volume button in, wait for boot to finish?
3. Press all at once <LEFT ARROW>+<RIGHT ARROW>+<info>
4. Unit will go thru a reset stage, and will (after a few minutes) re-start.
4a. Unit reports something...
5. Insert your .iso disc that you have made from this thread.
6. Unit may report "Unable to read CD/DVD", BUT, let it go......it should go through a firmware install process.
Does that sound correct??
2015 Polo Comfortline 6M + Driving Comfort Package
2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
(2008 MY09 Polo 9N3 TDI retired hurt hail damage)
So had another go:
1a. start up the RNS by pushing the volume button in, didn't wait for boot to finish
1b. force downgrade mode by pressing all at once <SETUP>+<EJECT>+<MIC> - held for 5 seconds
1c. wait...??will reboot automatically or needs to be restarted manually (can't remember)
3. Press all at once <LEFT ARROW>+<RIGHT ARROW>+<MIC> - held 5 seconds
4. Unit will go thru a reset stage, and will (after a few minutes) re-start like normal
6. Unit reports "CD/DVD Error. Please check CD/DVD", BUT, let it go......it goes through a firmware install process.
Splash screen with red bars:
"THE SYSTEM IS NOT ABLE TO START UP"
"PLEASE INSERT SWL-CD" (which is already in, so it is happy)
"NETDATA BOOTLOGO UPDATER" has progress bar, completes
Unit restarts with old splash screen.
Black screen with message.
Message changes.
Then "SOFTWARE LOADING VERSION (010101)" as per screen grab earlier post.
"SOFTWARE LOADING ERROR (....)" SWL ERROR
....nothing has been changed reboot.
So, it looks like the CD reads happily and there is some software conflict, perhaps because the software on the RNS-510 is fairly new??
Media read error.
Try to burn again at slowest possible speed. Use a different brand of media and or a different burner.
Burn using xpcdburner using track at once recording.
I have just done mine, here's the exact steps I did.
2. start up the RNS by pushing the volume button in, waited for boot to finish, ejected a DVD I had in it.
3. Press all at once <SETUP>+<EJECT>+<MIC> - Unit should reboot after a few seconds, if not force by <LEFT ARROW>+<RIGHT ARROW>+<MIC> (only need to press them, not hold them in).
After reboot, splash screen with red bars:
6. Select OK when prompted and it should complete in a few minutes.
2010 Candy White Golf GTI 5Dr. Manual, RNS-510, Bluetooth, Tints, GT-CX 18 Gloss Black Rims.
Apparently, the unit is a bit picky about how the ISO is burnt. Success at last.
So definitely, burn .iso image using xpcdburner select track at once recording, suggest slow burn speed (eg 4x). DVD-RW is reported to work by developer netdata. I used the same brand blank CD-R I tried before, which now works with no problems using the TAO burn.
2. start up the RNS by pushing the power/volume button in, don't have to wait for boot to finish
3. Press all at once <SETUP>+<EJECT>+<MIC> to set software loading mode, unit didn't seem to want to reboot by itself, so press power/volume button
5. Insert your .iso disc that you have made from this thread (using track at once recording)
netdata says the software doesn't attempt to change any part of the firmware, so there is no risk of bricking the unit.
Just put one of these on my GTI this arvo, thanks for the DIY. Ive seen it come up a couple of times but am I right in saying that the boot screen isn't shown every time the unit is turned on with either the key or the power on/off/volume button? I get the idea that it takes a while for the unit to power down..
MY09 MkV BMP 3dr GTI manual
Yeah they have a 'fast boot' mode that skips the full startup sequence if the car has only been switched off for like 30 mins or something. So overnight you get the full boot sequence which lets you see your custom image.
It is configurable via VCDS to force a full boot every time, but no idea why you would want that....if you really want to see the boot logo again, you can reboot it with the three finger salute...
Ah ok, good to hear it confirmed. Thanks mate.
Having successfully upgraded to FW 4020, I decided to change that bland startuo logo.
I read all of this thread and tried one of JohnC's iso files first without success.
I tried again after allowing "downgrade", but again no success.
I tried CDs and DVDs burnt as low as 2X, but no success.
I tried using CDs and DVDs burnt with downloaded netdata iso images, but no success!
I mostly get a screen showing a progress bar that takes about 3-4 minutes, the old logo then flashes up on the screen usually followed by an SWL error screen that ejects the disk and says that the original firmware will be displayed after restart.
Should I give up or try something else?
