Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: RNS 510/Columbus Map Scale On Startup
  1. #21
    Pacific Paradise QLD
    Ok, just went through the adaptation channels, coding and all setup/test mode options, there doesn't appear to be anything that would control this.
    Anyone want to be a guinea pig and try an upgrade to 5238 to see if it corrects it? I am on 5238 now but I have not ever seen these reported symptoms on any level of firmware from 26xx to 5238, with everything in between on my unit....
    Im with you, have just been for a drive and set the zoom at 25m and when i stopped to go shopping and restarted it was still on 25m.
    However when on auto zoom it has started on different ratios to what it was on when turned off.
    Could it be that it defaults to a certain zoom level when on Auto.????????
  2. #22
    Jan 2012
    Earlwood, NSW
    Quote Originally Posted by thezoneR32 View Post
    + one for this annoying glitch and its def since FW upgrade to 4120. Mine is an older c vers so I dont have the abilty to turn the dial and and change zoom it has to be done manually on the touch screen and its freakin annoying!
    I've got a Skoda Columbus 3T0035680B, which I'm sure equates to a RNS 510 C model. I've always been able to adjust the map scale via the right hand radio button/dial.
  3. #23
    Mine is a C which has been upgraded and the dial works Some you have to push in and turn.
  4. #24
    Jan 2012
    Earlwood, NSW
    It mostly goes up in 2X increments at each start up (75 to 150 to 300 etc). And then there's that infrequent, but mysterious radio station changing. Has to be a FW thing, but beyond me to be able to prove it.
    Edit: I only found out recently that if I push the right hand knob while nav guidance is on "she" will repeat the last instruction. Any other time I push it "she" says, "The guidance system is inactive".
  5. #25
    Nov 2009
    My bad I looked back over my firmware and build date etc and mine was a "B" version which I have upgraded to 4120 so hence no right hand button zoom functionality and no auto zoom. Not sure I'm game to go any further with firmware as even 4120 was pushing it.
    Volvo S60 RD T6
