The LC6i can work with only 1 set of inputs (L+R) and then output Line Level to 4 channels (F/R or F/S) - Under AutoMode Inputs in Manual.
If you installer did this then he's cheated you out of F/R fading from your head unit.
He's done this so he only has to run 4 wires (L+R pairs) of inputs to the LC6i.
He should have connected both the front and rear speaker wires to you LC6i and then you would have F/R fader control from your head unit.
When using AutoMode Inputs, you can then run Subs on Ch3 and they are controled by the Ch2 inputs - this then gives you 4 inputs (F+R) to 6ch output (F+R+S)
Which is how I intent to run when I get a LC6i
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
