Results 1 to 10 of 12
Thread: RNS 510 in 2010 models
    Jul 2009
    Can someone confirm or deny that a 4GB SDHC card will work in a 2010 model RNS 510?
    Jul 2009
    Highlands NSW
    SDHC Cards
    My manual for the RNS510 says
    "Memory Card Slot - The slot accepts cards with the dimensions 32mm x 24mm x 2.1mm. The unit supports SD and MMC memory cards with a capacity of up to 2GB and SDHC cards with a capacity of up to 32GB"
    Still have to purchase an SDHC card and see if it works but until then I will have to trust the manual.
    Mar 2009
    Melb
    I've successfully tested an 8gb microsd in a sdhc holder on my RNS-510 hw 02 and FW 2660
    Nov 2009
    Melbourne. Victoria
    1200 Firmware with mk6 rns510 b unit fails with 16gb SDHC, also pressing "i" button doesn't initialize voice controls but I have a mic installed for dealer fitted bluetooth option
    any ideas for either of these issues?
    Feb 2009
    To OP - Not sure, try it and see! If it doesn't then the unit can be firmware upgraded to support them anyway. I am using a 32GB SDHC in my 09 RNS510 that is running firmware 2660.
    To Alexmk6gti - 1200 firmware doesn't do voice control. How do you know you have 1200? "i" button just does nav repeat I think from memory? If it IS 1200, it should read the 16GB card though. Make sure it's FAT32 formatted and that there are some MP3s on it.
    Jan 2008
    Quote Originally Posted by alexmk6gti View Post
    1200 firmware is not upgrading all units to SDHC support whereas 2660 firmware is.
    Seems that some hardware revisions are not working with 1200. I don't suppose you have you HW : xx number from the top of the unit or out of VCDS?
    Nov 2009
    Melbourne. Victoria
    I just upgraded the firmware today to 2660 (i was under the impression that 1200 was newer since it had the newer release date on my-gti.com).
    Pressing the 'i' button still gives me nav instructions and pressing the 'mic' looking button on the steering wheel simply mutes the audio.
    I haven't tested my 16gb SDHC card since the update.
    Also is there a way to remove the region lock for DVD's - I believe because I've used the EU update it's now blocked region 4 DVD's - And i assume since a firmware update did this that a config file change on the update disk may be able to change that back? I know it's possible to do with a cable and ripping the headunit out but i'd rather not a)buy the cable b) take the unit out.
    btw this is a Mk6 GTI with a factory fitted RNS510 (so I assume it should be the latest hardware spec)
    The follow info was pulled from the test menu under 'version info' (probably an overkill with info but here it is..)
    delivery part number: 1T0035680C
    HW-Version: H11
    SW-Version: 2660
    SV SW-Version: C_EU_9242_t300
    HW Vehicle: 0xC201
    SW Vehicle: 0x44340010
    Bootloader Vehicle: 0x44340001
    HW Main: 00010002000201 ...
    SW Main: /L2.0_P16
    Bootloader Main: 00132013
    HW Radio: 0004
    SW Radio: EUR_CHN_141W
    Bootloader Radio: A2CSWDNL0010001
    HW DAB: -
    SW DAB: -
    HW DVDDecover: 004(0x04)
    SW DVDDecoder: _S0_S7.0
    HW DVD Drive Vers...: A2C53173871
    SW DVD Drive Vers...: VW1_C0_C.4.1
    IBOC HW Version: -
    IBOC SW Version: -
    HMI XML: 1.13.6.5 (EU)
    Feb 2009
    the i and mic buttons will continue to do that until you tell the RNS to enable voice control using VAGCOM. http://www.my-gti.com/1234/volkswage...-voice-control
    Jan 2008
    [QUOTE=alexmk6gti;418252]I just upgraded the firmware today to 2660 (i was under the impression that 1200 was newer since it had the newer release date on my-gti.com).
    1200 is the release that doesn't include all the new features of the 2660 release. This is for older hardware versions and includes the 32GB SDHC support and poi photos.
    You can't make the unit region free, you can however set it to a region. You have to use vagcom/vcds to do this.
    Changing the Region Code on the Volkswagen RNS 510
    2660 should operate fine with your unit as it's a revision C.
    Nov 2009
    Melbourne. Victoria
    My 16GB sdhc works now after the 2660 update
    I'll look into purchasing the VAGCOM cable to enable australian DVD region and voice recognition.
