ok electrical minded people need a bit of help i want to convert my cd stacker cable which as a 13 pin din end to a 12 pin (9 pins actually used) trunk connector i have the pin out for the cd stacker connection but not the 13 pin out
connection to stereo pin out
and this is what i have found for the trunk cable
also found this
Here is what I was able to find:
pin# -- Function
1) Data In
2) Data Clock
3) Primary Ground
4) Data Out
6) +12v Constant
7) Right Channel Audio
ACC / Ignition power
9) Audio Ground
10) Left Channel Audio
