Results 1 to 10 of 12
Thread: Reversing camera has dropped a colour
    Aug 2016
    Put my 2011 Passat into reverse today and discovered it's viewing the world through rose coloured glasses
    Reversing camera has dropped a colour-capture-jpg
    Looks like maybe I've lost green from the RGB camera or something? Any thoughts on the cause and the fix?
    If I were to take a wild stab in the dark i would guess maybe the wiring going through the boot grommet from the camera to the head unit.
    Otherwise if it's an aftermarket camera, it will have a CVBS to RGBS converter sitting behind the head unit. Try unplugging and reconnecting it.
    Aug 2016
    Is it 3 separate wires carrying R, G and B signals from the camera to the head unit? You don't happen to know where I can get a B7 Passat workshop manual so I can work out how to get into the guts of the car?
    Adelaide hills, SA
    Quote Originally Posted by brettue View Post
    You can download it for a small fee from Erwin.
    If its a factory camera it is a composite signal that is then converted into RGBS to go into the head unit.
    Try just pulling it out and reseating the 25 pin black multimedia connector towards the bottom of the back, it has a white locking bail arm.
    Aug 2016
    It's factory. Bottom of the back of what, the tailgate or the RDS-510 (which is what I assume it connects to)?
    Pacific Paradise QLD
    Its an RNS 510 and I have sent you required info
    Aug 2016
    OMFG, thanks kamold, that worked! So easy to remove the head unit too, 1 bit of trim and 4 scews. I'm so happy.
    May 2012
    Bushland Beach, QLD
    The reversing camera on my 2012 Tiguan Pacific with RNS 510 did exactly the same. It suddenly was showing purple tinge on screen and then a couple of days later I have no image at all, just a black screen when reverse is selected. I think the camera has died and will need replacing. Any advice on this would be appreciated.
    Aug 2016
    Quote Originally Posted by gwarra View Post
    Yeah, the reset fixed the purple tinge for about a month, then the camera died outright just like you expierenced. To be honest unless I'm hitching up a trailer (which is almost never) I don't use the camera, just the proximity alarms, so I've not tried to fix it.
    If you do fix it gwarra, let us know how.
