Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Reverse camera prob
    Jan 2012
    Epping, NSW
    Thanks guys.
    So, I pulled out the stereo just now, and it (looked) to be clipped in perfectly with the lever across where it should be, but none-the-less I unclipped it and clipped it back in, and hey presto, a rear camera image!! Wonder if it needs a bit of WD on the pins or something, strange. Lucky it is a piece of cake to get to the stereo (unlike the camera in the back, what a pain those metal clips are! well, they are a pain for the stereo surround also, but a minor pain haha).
    So, back to my other question, do you need to always press the on screen button to see it? When I was fiddling yesterday, I did manage to get OPS on the left (and black on the right), I will try to find how I managed that and see if it can do OPS & rear view camera simultaneously.
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
    Quote Originally Posted by DkN View Post
    I think he means HE shouldn't post and drive and that his post didn't make sense
    And here I was thinking text & drive was bad
    You are correct
    Good to hear issue is sorted
    Sent from my HTC One X using Tapatalk 2
    Jan 2012
    Epping, NSW
    ok, found it.
    in the "10-Park/Steer Assist" module, byte 1 bit 5 is "rear view camera installed"... once you tick that (along with the RVC in the navigation menu which is well documented in all the online guides) you will get the OPS on the left of the image, like so:
    yes, that is the garage door...
    So if anyone needs a hand for a bourbon or three, I can both program & install these things now . I think I also have a spare chineseVCDS cable (have to go to the post office & pick it up tomorrow, see if it is ok, had to repair the one I had, wasn't sure I could resurrect it).
